PXI
How do sync data acq between two PXI chassis?
I have a pxi-1010 chassis with an 8176 processor that is linked to another pxi-1010 chassis (no processor) via mxi-3. I have four 6071E analog input cards in each chassis. The primary chassis uses thr RTSI line to sync the 6071E cards to get data at 200 Hz every 1/2 second. How can I sync the 6071 E cards on the extension pxi chassis? Does the MXI-3 connect the RTSI buss to the second chassis?
(3,436 Views)
No, the MXI-3 connection will not connect the two chassis's RTSI lines together. However, you can take advantage of the PFI lines on two of the DAQ boards to output/input these signals between chassis.
In fact, here is an example program that demonstrates synchronizing two boards using the PFI lines.
Synchronize Two E Series Boards Using PFI or RTSI:
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E61156A4E034080020E74861&p_node=DZ52336&p_submitted=N&p_rank=&p_answer=&p_source=Internal
I hope this helps!
-Russell
httP://www.ni.com/support
(3,436 Views)
Russell,
Thanks for your response. I can't open the shortcut. I get a server not found error.
(3,436 Views)
