PXI
How do you configure multiple PXI 1011 chassis' in MAX?
I have two PXI 1011 chassis'. The first has the MXI-3 card hooked to a MXI-3 PC card through fiber. The second chassis has an 8176 controller and the 6052e GPIB card. Both chassis have multiple SCXI cards. The problem is the configuration in MAX. MAX 3 picks up the MXI-3 card and chassis with all the SCXI modules, but will not pick up the 8176 chassis. This 8176 is hooked to the PC through a CAT5 ethernet switch.I know there are problems with multiple chassis configuration, but I'm sure I'm just missing something here.
(3,332 Views)
So it sounds like you have two PXI systems that are not connected or related to each other, is that right? Since your PXI chassis connected via MXI-3 is working fine, we�ll take that out of the equation.
It sounds like you are trying to configure your PXI-8176 system as a Remote System through an Ethernet connection. Is your PXI-8176 running Windows (if so which version) or Real-Time (RT) operating system?
If you are running Windows XP on the PXI-8176 and also on your computer you can use XP Remote Desktop to control your PXI-8176 system through Ethernet (see the following link for information on that):
http://digital.ni.com/public.nsf/websearch/C074C33F4DE3FA5186256D3D007788DA?OpenDocument
Another option is to use Remote Device Access (RDA) to cont
rol your SCXI modules and DAQ board (6052E). RDA will only work with Traditional NI-DAQ, it is not supported in NI-DAQmx. I�ve included a couple of links for KB�s that have more information on RDA for you.
http://digital.ni.com/public.nsf/websearch/3a4d2f5f4354e53a862568c0006a8bc0?OpenDocument
http://digital.ni.com/public.nsf/websearch/5CC9792C6CD4A34C862565BC0072D5DF?OpenDocument
If you ordered your controller only with Real-Time on it you can use the following document to configure and troubleshoot your PXI-8176 RT system.
http://www.ni.com/support/install/install_configure_6.htm
I hope this helps you.
Doug K.
(3,332 Views)
