PXI
How many tasks can I have in NI-DAQmx system?
Hello Hassan,
Connections to the 2575 are made through an LFH200 cable and TBX-50 connector blocks.
This document describes what pins correspond to which connections of the multiplexer.(Pgs 16 and 22 have the information used below)
For the 1 wire 196 to 1 mux:
Common- Pin 23 of connector P4
CH0-Pin 1 of connector P1
CH1-Pin 3 of connector P1
CH2-Pin 5 of connector P1
CH10-Pin 21 of connector P1
and so on.
So the amplifier output would be wired to P4 Pin 23, and CH0-10 would be wired to the ten connections on your device.
Are you using an NI Function Generator? If not, how is it controlled, GPIB, Serial, a separate driver?
If I understand correctly, you want to:
Generate Phase 0, then connect common to CH0
Wait, then disconnect CH0
Generate Phase 90, then connect common to CH1
Wait, then disconnect CH1
So on through CH10
Is that correct?
Luke B.
Message 11 of 11
(742 Views)
