PXI
How should I proceed for cloning the HD from a controller of a PXI mainframe?
In a PXI-1000B mainframe with a controller 8156B, we need to clone the hard disk for safety interests. We already have a 2,5" IDE hard disk, now we need to transfer data. Is it possible to proceed as I'd proceed in a standard PC? (That is installing the second HD as slave and clone with the Nor5ton Ghost application).
(4,304 Views)
Hello!
PXI Embedded Controllers are computers, so it is possible to do many things you would with a desktop PC. You could set up the second harddrive as a slave, however, you would need to provide the cabling to attach a second harddrive. Due to the compact build of the PXI embedded controllers, it could be difficult to connect both harddrives at the same time. It may require "taking apart" the controller to achieve this.
An alternative would be to configure the ghosting program to work over a network. Then you could ghost the 2nd harddrive without any modification to the PXI controller.
(4,304 Views)
