PXI
How to Perform Memory and Disk Integrity Tests on a PXIe 8133
Hello everyone, after 10 years of trouble-free operation, I have been having problems with a program that runs on a PXIe8133 for some time now (acquisition interrupted with error message 200279). I wanted to do a preliminary check of the physical integrity of the PXIe memory and disk. Only the RT operating system is installed on the PXIe, there is no Windows. Is there a procedure to do a check? Is it necessary to install Windows from USB and try to do the checks from Windows?
Thanks in advance,
Andrea
(566 Views)
You can run Hard Drive Diagnostic Utility for NI PXI(e) Embedded Controllers
https://tmesystems.net/
(545 Views)
