PXI
How to Reinstall NI-DAQmx on a PXIe-8880 via remote
Hi everyone,
I’m having trouble reinstalling NI-DAQmx on my PXI system and could use some guidance.
Here’s my setup:
  • Chassis: PXIe-1092.
  • Controller: PXIe-8880, connected to my laptop via Ethernet.
  • Modules installed: PXI-6521, PXI-6515, and TB-4340.
The issue started when I uninstalled NI-DAQmx due to a compatibility error with the version I was using, which didn’t support the PXI modules properly. Now, I’m unsure how to transfer and install NI-DAQmx on the PXIe-8880 from my laptop over the Ethernet connection.
My questions are:
  1. How can I confirm the correct version of NI-DAQmx for this configuration?
  2. What is the procedure for installing NI-DAQmx on the PXIe-8880 from my laptop?
Any advice or tips would be greatly appreciated.
Thanks in advance for your help!
Best regards
(650 Views)
Accepted by topic author saulog
You didn't mention the software version and the OS of your PXIe-8880. It could be either one of these steps:
https://tmesystems.net/
(635 Views)
On the PXI is Linux and the laptop is Windows, thanks for the info.
(586 Views)
