PXI
How to add PXI 40 295 Module into the MAX?
I have a PXI 40 -295 from PICKERING, I have installed the the driver. the module shows on the PXI-1042 system, but i don't know how to assign the device number for it?
can i any1 tell me?
i m using LabView 7.1
(3,178 Views)
Jcal,
I am not sure how the Pickering Modules work.  Do they have drivers to make the HW compatible with NI Software?  You may be able to just reference it by the VISA Address listed under the PXI System in MAX.  You may want to contact Pickering to see if there is any additional drivers that may need to be installed.
Lon. A
(3,166 Views)
