PXI
How to boot PXI controller using VxWorks
Kindly let me know the following in PXI
1. How to boot PXI controller thru floppy/any bootable device using VxWorks 5.4 ?
    Whether a manufacturer BSP is required prior to building the VxWorks image ?
2. How  PXI-8421 comport base address can be obtained ?
Thank U
with regards
jlaxb
(3,813 Views)
Which floppy controller do you have?  For the controller you can change the bios boot order to boot from the floppy or USB before the Hard Drive in order to boot from those devices.  Also do you currently have VxWorks on the controller and what version is currently on there or what Operating system if any?
Daryl E
(3,796 Views)
can you please tell me how to make hard disk bootable for vxWorks.
(3,066 Views)
