PXI
How to generate PWM signal with crank signal in the HIL system?
Hi everyone! I am dealing with a project about vehicle Hardware in the loop (HIL). When generating the PWM signal, a labview vi of PXI 7831R is used. But I do know the relationship between the crank signal and the PWM signal. Is there anybody who is familiar with vehicle HIL?
Thank you.
(2,554 Views)
(2,535 Views)
It does help me. Thank you! By the way, are you familiar with HIL or project which is similar to the example that you show me? I have sent you a private message.
(2,533 Views)
