PXI
How to generate a train of pulse with a PXI 6250
I have a PXI NI-DAQ 650 with only 2 counter /timer
I have to use these two counter timer to generate  2 signals  for my hamamatsu linear camera
A) a MAsterclock signal corresponding to a given  pixel
B) a MAster Start trigering acquisition of a row ( camera integrates signal between two master start
I would like to control Naccu the number of acquired lines i.e. generate a Naccu master start pulse
I tried to use the finite sample Sampling mode instead of continuous but in that case an error 50103 appear when starting the counter
Q1) did any one try this kind of mode
Q2) does anyone got the same message of error
Best regard
Thibaut VINCHON
(3,035 Views)
When you do a finite pulse train generation two counters are used this why you have error 50103.
You can see this link:
http://digital.ni.com/public.nsf/allkb/160DDB88169245B786256D600066DFB0?OpenDocument
Regards
VéroniqueD
NI France
(3,022 Views)
