PXI
How to generate clock with PXI-6541 ?
I would like to generate a clock signal on DIO:0 of PXI-6541 ?
i didn't find example on web or there are too complicated for my application.
My objective :
Just a box where i write the frequency and an other box for the channel choice.
 After, i have an external oscilloscope to check the signal...
do you have an idea ?
best regards
(4,218 Views)
After perform internet searches, i found that the output frequency is always 50MHz/n with n=2, 4, ... so i can't provide 11,4MHz (11,7MHz is the closer frequency).
But on the PXI-6541, there is an CLK Input which allow to change this internal frequencie and so, I will can provide all frequencies I want.
Have you alreeady use this or have you any example of this use ?
(4,211 Views)
This example will maybe help you
C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\instr\niHSDIO\Dynamic Acquisition.llb\Dynamic Acquisition with Reference Clock (PCI).vi
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(4,172 Views)
