PXI
How to install LabVIEW RT operating system on PXI
I have a PXi Controller 8840 with a defekt hard disk.
So i changed the hard disk und get the now one formatted with the "Ni Max"
No i have the Problem that i can not  install the Software Drivers with the "NI MAX"
There are solso no PXI Slots in the "NI MAX" to see.
The System State is: "no Software intalled"
Do i have to install first the "LabView RT Operation System" on the hard disk of the PXI?
But How?
(2,439 Views)
First make sure the connection between your host PC and the real-time PXI is established. Are the IP adress, the IP configuration set correctly and does the status say "operational"? Restart the PXI, having connected a computer monitor before to the PXI; what is shown in the screen?
Good luck
(2,400 Views)
