PXI
How to install Windows 7 on PXI 8110 controller
Hi
I have PXI 8110 controller that is installed Windows XP on.
But I have to change the OS to Windows 7 SP1.
What should I do ??
Message 1 of 9
(4,283 Views)
Sefaa,
According to the manual for the 8110, "The NI PXI-8110 supports the installation of Windows 7, XP, and Vista from a USB CD-ROM."
You will want to get an installation CD for Windows 7 and use an external CD-ROM drive.
Here are a couple more articles that talk about it:
http://ae.natinst.com/public.nsf/webPreview/C121B7EB066F078D86256D6A0062E317
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7ZsSAK
VanCamp
Message 2 of 9
(4,248 Views)
Sir, you are right. But I want to learn whether I can install Windows7 SP1 on the controller.
I am asking this question since I do not know the difference in between Windows 7 and Windows 7 SP1.
Note: To run Visual Studio 2017 on the PXI controller, I have to have Windows 7 SP1 at least.
Message 3 of 9
(4,230 Views)
sefaa,
The only significant difference between system requirements for Windows 7 and Service Pack 1 is the disk space, which shouldn't be a big deal unless you've filled up most of the hard drive. It only requires a few extra gigs.
Here is an article that talks about the disk space differences: https://www.ghacks.net/2011/02/20/windows-7-sp1-all-you-need-to-know-and-do/
Hopefully that helps.
VanCamp
Message 4 of 9
(4,226 Views)
Sir, for example I tried to install LabVIEW 2016 and LabVIEW 2017 softwares to a computer that has Windows 7 Professional today. But at the begining of installations, it gives me "It is required Windows 7 SP1 or later" error.
This can be given as an example for what I mention.
For Visual Studio 2017 software, it is required Windows 7 SP1 at least as well.
But I can only install Windows 7 / XP / Vista in NI PXI 8110 Controller.
I definitely have to install Visual Studio 2017 software in NI PXI 8110 Controller.
So, what kind of OS should I install to the NI PXI 8110 Controller??
Message 5 of 9
(4,219 Views)
sefaa,
Why do you say you can only install Windows 7 / XP / Vista? This requirement for the controller most likely includes the service packs.
Have you tried installing Windows 7 Service Pack 1 on the controller? You should be able to.
VanCamp
Message 6 of 9
(4,211 Views)
This is actually the asnwer of what I asked, sir.
I did not try to install Windows 7 SP1 on NI PXI 8110 Controller. But you say that I can install Windows 7 SP1. So there is no problem.
I will try and inform you about the result.
Message 7 of 9
(4,209 Views)
Hi sir
I installed Windows 7 SP1 OS yesterday, so for now there is no problem. For your help, Thank you.
Now I have to install required drivers for the peripherals. I downloaded the drivers from this link http://www.ni.com/download/ni-pxi-8110-peripheral-drivers-1.0/1309/en/
to use NI DAQmx, NI Serial, NI VISA, NI Ethernet functions etc., is it enough to install the drivers above??
Or when I install LabVIEW 2017 software, these drivers will install automatically ??
Message 8 of 9
(4,162 Views)
sefaa,
The peripherals does not include National Instruments drivers. They won't be included in LabVIEW either. You will have to install NI DAQmx, NI Serial, etc one at a time from our website.
Just do a google search for "NI-DAQmx 17 Windows 7" or whatever other drivers you need.
VanCamp
Message 9 of 9
(4,154 Views)
