PXI
How to program downconverter?
I have to dowconverter together when digitizer and I would like to know as I make to lower a frequency of 70Mhz for 10Mhz, using only dowconverter.
Eduardo Cesar
Thanks.
(3,536 Views)
Good afternoon Eduardo,
You should be able to use the NI-Tuner VIs to lower your desired frequency from 70MHz to 10MHz.  There are a few examples available to give you a good idea of the general NI-Tuner programming flow.  You can find these by going to Start > Programs > National Instruments > NI-TUNER > Examples.
You can also have a look at the VIs by going to:
All Functions > Instrument I/O > Instrument Drivers > NI Tuner.
You didn't specify the span required but the NITuner Getting Started.vi should show you how to control both the frequency and span via the niTuner Set Frequency.vi
The NI-Tuner Reference Help is a great resource for using your 5600, and is located at Start > Programs > National Instruments > NI-TUNER > Documentation
Please let me know if you have any further questions regarding this issue.
Sincerely,
Minh Tran
Applications Engineering
(3,524 Views)
Where can I get NI-TUNER?
or
on which CD?  We get a CD book from NI.
George Zou
(3,493 Views)
If you install the RFSA/RFSG software, than NI TUNER is automatically installed.
You can locate it by right-clicking on the block diagram and going to
Instrument I/O > Instrument Drivers > NiTuner.
The RFSA/RFSG drivers can be found right here:
Best of luck on your project,
Minh Tran
(3,487 Views)
