01-17-2011 04:35 PM
Labview RT10.0 is installed on our new PXI-e8133 controller. Our host is running Labview RT8.2. Therefore I am unable to download and run a VI from the host to the remote system.
I want to download RT8.2 from the host to the target (thus replacing/removing RT10.0 on the remote system). On another controller, we were able to choose the "older" RT8.2 for download in MAX (replacing the newer version). This is not an option with the new controller. In MAX add/remove software, the available versions of RT on the host is "none" (even though RT8.2 is listed under software on My System).
How do I install RT8.2 on the remote system? Do I need to completely remove RT10.0 first from the remote system?
Thanks!
Solved! Go to Solution.
01-18-2011 11:42 AM
Unfortunately, the minimum compatible LabVIEW RT Version for the PXI-e 8133 is 2010. This means that you'll either need to upgrade to LV2010 or choose a different controller.
David Ashlock
