PXI
How to sync mutiple PXI RT controllers
I have three independent RT PXI chassis each with a 8071 controller, each will be acquiring data and performing motion control. What would be the best way to sync all the motion and acquisition applications on each system.
(4,509 Views)
It sounds as though you want each one of your programs running on each independent RT PXI controller to start in software at the same time. I would suggest using TCP/IP commands between the PXI controllers. However this will not be deterministic, therefore I must ask how closely do you want your programs to start together?
Regards
Russell Blake
Applications Engineering
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(4,509 Views)
Hi Larry,
This topic intrests me but I have had an opertunity to do one of these yet.
As mentioned in the other answer, we need to know "How close the sync the to be".
I can only throw out two ideas.
1) CAN bus is supported under RT and has deterministic mode.
2) TCP/IP and hardware combo. Run a single sync signal to all of the RT systems and use it to clock all of the systems. Use TCP/IP to let each RT system know it should set up its I/O and start watching for the sync.
I would like to know what approach ends up working for you.
Ben
(4,509 Views)
Ben
The answer to how close of a sync do we need is something between 500 to 100 ms.
Right now my ideas are everyone start & stop on an event say a TCP/IP or UDP message. All the chassis have PXI DAQ modules and using DIO lines is another approach.
With this said I was wandering if there is a PXI bus line that may be used. I looked at the pin out and description of the PXI bus but nothing jumped out so I just wanted to make sure I have not missed a PXI bus or module option.
Larry
(4,509 Views)
The answer to how close of a sync do we need is something between 500 to 100 ms. The sync I am intending is between processes running on each system
not so much as software starting and stoping.
Larry"
(4,509 Views)
If you have multiple PXI DAQ board you can send a trigger pulse from a master board to a slave PXI DAQ board through RTSI for one chassis. Then send a trigger pulse across a PFI line from a slave in the first chassis to a PXI DAQ board in the second chassis.
Regards
Russell Blake
GCentral
(4,509 Views)
We have added a PXI-6602 to each of the chassis they will be used primarily for encoder monitoring. So can we use PXI-6602’s with the PFI lines? Also what a good source to get educated on PFI lines.
Larry
(4,509 Views)
