05-11-2006 11:37 AM - edited 05-11-2006 11:37 AM
Message Edited by twayne on 05-11-2006 11:41 AM
05-12-2006 02:47 PM
Hi twayne,
What type of NI PXI cards do you have in the chassis that you are trying to synchronize?
05-16-2006 02:49 PM
05-17-2006
12:48 PM
- last edited on
11-14-2025
04:54 PM
by
Content Cleaner
I did some research about this and unfortunately we don't have any documentation for GPS synchronizing using the ZTec ZT1000PXI GPS card and onboard clocks of the NI cards. The info we have available for GPS synchronization is listed here, but this setup is using PXI-6608 counter card. However, some of the information given might give you ideas on how to implement it in your setup.
Another option that you can try is to put some kind of clock on the backplane and see how each measurement device can synch to that clk/pulse.
Sorry I can't me more helpful at this time.
05-17-2006 01:08 PM
Hello again,
I actually think that putting the clk on the backplane was what was intended for this system. I just dont know how to do that. Can you give me any pointers for trying to get this set up?
thanks.
05-18-2006 03:18 PM
You can use the 6608 card to generate a 10MHz clock which will overwrite the chassis clock on the backplane. Then you can use this clock to synchronize it with your GPS card. Once the GPS card is in synch with the 6608, then you can use this timebase as reference clock for controlling all other cards. As far as how to the implementation of the 6608, please refer to the link I proved it the previous post.
