PXI
How to synchronize sampling on PXIe-5162
Hi, I need to characterize phase and amplitude imbalance of two quadrature signals from a 14bit TxDAC. I selected two 5162 modules to do the job. The signals can have a frequency of up to 1.2GHz..
Is PXIe-5162 capable of doing this job?
The plan was to record a long sample of the signals and then do the processing in ie. Matlab.
I am facing a few problems. Is it possible to synchronize sampling of all channels on one 5162 module, and how to synchronize sampling of 2 x 5162 modules with enough accuracy to have a phase resolution below 1deg?
Are there any examples of how to synchronize sampling of multiple channels/modules in LabView ?
Can the phase and amplitude measurement be done directly in LabView without involving Matlab?
(5,670 Views)
Hi Robert,
Did you already read some white paper and KB about synchronization using LabVIEW?
https://www.ni.com/en/support/documentation/supplemental/10/synchronization-explained.html
https://www.ni.com/en/support/documentation/supplemental/06/timing-and-synchronization-features-of-n...
You can find some other white papers on ni.com. I think this will be a good start before doing something else.
You also can search in the LabVIEW examples.
Here some information about the measurement of the phase and the amplitude:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/0measdsp-llb/amplitude-and...
https://www.ni.com/en/support/documentation/supplemental/06/statistical-visualization-in-labview.htm...
Let me know if it is good 🙂
Certified LabVIEW Architect (CLA)
(5,639 Views)
Thanks for a reply.
I read a bit about the NI-TCLK synchronization. Does it apply to module-to-module sunchronization or is it used within one module too?
I found this page
Overcome the Challenges of Building High-Channel-Count, High Speed Measurement Systems
It says 30ps skew after manual calibration, which is not enough for my application.
I didn't find any information about the sampling skew for converters within one module.
I recall a number 12ps from some previous research but I cannot find it now. 12ps within one module is still too much.
(5,635 Views)
Hi Robert,
From the datasheet of the 5162 (https://www.ni.com/docs/en-US/bundle/pxie-5162-specs/page/specs.html) page 20, its says that using the manual calibration you can synchronize two identical 5162 with less than 5ps.
Here some other information:
https://www.ni.com/en/shop/pxi/national-instruments-ni-tclk-technology-for-timing-and-synchroni.html...
Is that answering your questions?
Have a nice weekend.
(5,622 Views)
