PXI
How to trigger a case structure/while loop with PFI1?
  I have two while loops in one VI, one is a high speed (RFSA) read loop that is triggered by PFI1 via DAQmx the usual way.  Inside this first loop is a DAQmx Read that waits for the PFI1 trigger that works great.
  I would like to trigger a second timed while loop (much slower) using the same PFI1 trigger.  It contains power supplies that I want to read at a 50Hz rate simultaneous to the RFSA reading.  My problem is that the hardware drivers in this loop speak VISA.  Note-The "trigger" function of these supplies is not the right kind trigger so I need to trigger their read VI with a case structure and while loop.  I have no idea how to extract the PFI1 from the DAQmx Task to use it to to trigger the case structure.  Any hints would be appreciated.
Jim
(4,511 Views)
Based off of what you said you are communicating with these devices using NI-VISA, which creates a problem.  VISA is a serial connection it will not have a common clock for your devices to syncronize to.
If you are not actually using VISA for your communication and I just happened to read this wrong coud you include a code snippit so that I can get a better understanding of your code?
Lastly there are many options for syncronization some overviews of how they work can be found here:
https://www.ni.com/en/support/documentation/supplemental/10/synchronization-explained.html
-Ryan
Ryan
Group Manager
FlexLogger
NI R&D
(4,470 Views)
