PXI
How to uninstall NI 8310 Driver
My computer crashed during 8310 Driver instalation.
I had to reboot it and it said, during the instalattion, that uninstalling wouldn't be possible but I can't reinstall it either.
Is there a way to force its uninstall somehow?
Thks!
(4,053 Views)
That's what appers when I go to Control Panel and try to uninstal it:
" The log file 'C:\WINDOWS\system32\Uninst.isu' is not valid or the data has been corrupted. Uninstalation will not continue. "
(4,052 Views)
Portuguese Version:
Olá,
Para desinstalar este software, você deve utilizar o software MSI Blast que é utilizado para a remoção de software da National Instruments.
Abra o arquivo que te envio em anexo msiBlast.exe e selecione a opção Show NI installers only e conforme a imagem que te envio selecione todos os arquivos relacionados ao NI-DAQ e depois clique em Uninstall.
Qualquer dúvida por favor entre em contato.
Obrigado.
Atenciosamente,
Luciano Borges
National Instruments Brazil
English Version:
To uninstall this software you should use the MSI Blast software, that is a software used for uninstall NI software.
Open the file I attached here, select the option Show NI installers only and select all the software related with NI-DAQ as show in the image that I also attached here.
Let me know if you have any question.
Regards.
Luciano Borges
Luciano Borges
Test Development Engineer
(4,034 Views)
