PXI
I am using the PXI6713 analog output board in my system (many of them). Is the SCB-68 s
hielded I/O connector block compatible with this board? Is there a standard cable that connects the PXI6713 to the SCB-68. What is it? I would like to use this setup because I have some simple signal conditioning components to reduce the output voltage.Please respond promptly and answer my questions directly.
(4,061 Views)
hielded I/O connector block compatible with this board? Is there a standard cable that connects the PXI6713 to the SCB-68. What is it? I would like to use this setup because I have some simple signal conditioning components to reduce the output voltage.Buck;
Your answer is yes.
The SCB-68 Terminal Block can be used together with the SH68-68-EP cable and the PXI-6713 board.
Regards.
Filipe
(4,061 Views)
