PXI
I need an example explains how can i use PXI6602 to measure encoder position, velocity, and acceleration using LabVIEW 8.2?
(3,543 Views)
Finding the velocity and acceleration can be easily accomplished by simply using some shift registers and dividing the position by the sample time. I have modified the Measure Angular Position.vi that ships with LabVIEW to demonstrate one way to get the velocity and acceleration.
Adam
(3,526 Views)
Could you  show this in LabView 7.1?
(3,498 Views)
Here is a version of the example that will run on LabVIEW 7.1.
Adam
(3,489 Views)
