PXI
I tried to upload the Pxisys.ini file and MAX is showing the slot ID ...but i need a function to return those slot numbers..such that i can use in my DLL
hi hamilton,
thanks for your reply .
I already tried the option or pxisys.ini file
The MAX is showing the slot number ..but My requiremet is to use the slot ID in a DLL
so I need a function type of statemen to return or get the slot number of the NI devices on the PXI.
I think I clearly explained.
I would like to get the slot numbers through a software fucntion such that i can use the slot numbers values for some other purpose ,,like configuration ,,
(4,321 Views)
jayamurugan,
This functionality currently is not built into National Instruments software. You can get the device number, but not the slot numbers programmatically.
Trey Hamilton
http://www.ni.com/support
(4,321 Views)
