PXI
I want replace Tektronix scope,Agilent Multiplier and Tek Function Generator with NI equivalent hardware
I want to replace follwing  Tektronix scope,Agilent  Multiplier and Tek Function Generator with NI equivalent hardware.
Tek Scope(DPO4034B)
  • 350 MHz
  • 2.5/2.5/2.5 GS/s
  • 1/2/4 channels
  • 20M record length
  • 4-channel digital phosphor oscilloscope
Tek FG(AFG3000)
  • 10 MHz, 25 MHz, 100 MHz, or 240 MHz Sine Waveforms
  • 14 bits, 250 MS/s, 1 GS/s, or 2 GS/s Arbitrary Waveforms
  • Amplitude up to 20 Vp-p into 50 Ω Loads
Agient 34980A
  • 8-slot mainframe with 21 mix-and-match plug-in modules
    - Up to 560 2-wire multiplexer channels or 4096 matrix cross-points
    - Switching DC to 26.5 GHz, digital I/O, D/A converters and counter/totalizer functionality
    - Scans upto 1000 ch/sec
  • Optional built-in 6 1/2 digit DMM
  • LAN, USB 2.0, and GPIB connectivity
Can I build our own vi fucntion for the same with generic high channel count singke digitiser? If yes kindly tell me part number.
or please tell me the specific functions hardware which can provide same or equivalent functionality
Thanks & Regards
Regards:
Vaibhav Kanchan
Sr. Engineer
NI Certified LabVIEW Developer(CLD)
NI Certified TestStand Developer(CTD}
(5,446 Views)
All big guns! I am waiting for ur response
Regards:
Vaibhav Kanchan
Sr. Engineer
(5,420 Views)
Hello Vaibhav,
I apologize for the delay. I suggest that you give us a call at (888) 280-7645 so we can discuss the available options in detail.
Best,
Tarek B
(5,297 Views)
