PXI
I want to call the DMM- SFP from Teststand using IVI
Hi I have a Teststand 3.0 system with a NI-PXI 4070, and I want to call the DMM-SFP from Teststand using the IVI driver architecture. Unfortunatley I cannot figure out how to link the DMM-SFP to the Logical name.
(3,164 Views)
ADL,
If you are using the TestStand IVI step types, after you have added the logical name in MAX, you can insert an IVI DMM step type. Then right-click on the step and choose "Edit IVI Dmm". You should be able to choose from the Logical Name Ring Control the logical name you created in MAX.
If you haven't added the logical name into MAX, depending on what version of MAX you have, you can refer to Using Measurement & Automation Explorer 2.x to Configure Your IVI System or look in the IVI help that comes built into MAX 3.0.
If you checked there already or have another question, please let us know!
Shannon R.
Nati
onal Instruments
(3,164 Views)
