PXI
IRIG-B AM incorrect Year
We have an issue with an PXi 6683H returning the wrong year. This is because the IRIG-B reference that I will be accessing is returning status information in bits 50-58 of the IRIG-B packet (see: link ). The driver for the 6683 will substitute the system year if this field is zero (I have checked this and it works fine). I may be able to update the format source of my IRIG-B but it will be hard to gaurantee this across a range of installations. I would like to persuade the driver just to ignore the year regardless and use the year from the system. Is there registry setting to do this?
Message 1 of 1
(2,225 Views)
