PXI
Imaq RT Video Out using PXIe-8135
Hi all,
I am planning to get a PXIe-8135 RT controller and have a requirement to display the image out via the DP port. My questions are:
1. The IMAQ RT Video Out does support PXIe-8135, doesn't it? My concern is because the controller doesn't have VGA or DVI but DP (DisplayPort). Will it work the same?
2. PXIe-8135 has two DP's. Assuming the answer to Q1 above is positive, can I display two different images to both of the DP's?
Please advice.
(5,394 Views)
Hi Shazlan,
1- Yes PXIe-8135 RT controller do support IMAQRT Video Out function.
2- I'm not sure if it's possible since the 2nd DP is just an extended display of the 1st DP
Laila
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(5,353 Views)
