PXI
Initialize Multiple NI6555 Cards as A Single DIO
I am currently working on adapting an existing Test Executive Shell (written in C#) onto an NI PXIe system. The system has 4 NI6555 cards, and needs to be able to test several different PCBs, some with more than 24 I/O pins. The original system had the ability to initialize all Digital IO cards as a single unit with channels 0-96, as opposed to 4 seperate cards each with channels named 0-24. The goal was if for example an engineer needed to write a test that accessed pin #75, the drivers would link that pin to channel #16 of the card in slot 6.
Is it possible to initialize more than one card at once, and have the drivers treat them all as a single card? If not, is there a simple alternative? I am currently writing these drivers in C# and using the C to C# wrapper.
Thanks!
Jason
Message 1 of 1
(4,604 Views)
