PXI
Installing pxi-6551
I am having problems establishing a connection with my PXI-6551 HSDIO card in MAX. I am installing the card into NI PXI-1031 chassis with MXI-4 connection monitor. I have verified the card works on a different chassis, and I know the chassis works because I have a PXI 2503 switch card that is properly function. The pxi-6551 was successfully installed from the NI System Driver Set disk, however I can not the MAX to perform a self test on the card. I generate the following error:
The device self test has failed. The error report from the device drivers as follows:
Error -50251 occurred at Self-Test
Possible Reason(s):
NI Platform Services: The specified software component is not available. The component was not loaded.
Can anyone help with this?
-Milhouse
(4,119 Views)
I fixed the problem. Some how the the latest driver set disk did not have all the necessary drivers for the DIO card. I rolled back the install to the February 2009 driver set disk and it work.
-Milhouse
(4,095 Views)
I encountered the same error with the USB-4065 DMM.  The problem went away when I added "C:\Program Files\IVI Foundation\IVI\Bin" to the PATH.
(3,900 Views)
