PXI
Interchange DIN 96p connector (SH96-96-2)
We will be using the PXIe 4302 with the 96p DIN connector. Unfortunately that connector is too big for our end application.
Are there other cables available, besides the SH96-96-2 with a different end connector?
Or is it possible to remove the male connector and attach a different on to the SH96-96-2?
Or is there a PXIe 4302 variant without a backplane connector on the front?
Kind regards,
Bram
(381 Views)
You need to create your own breakout cable into custom connectors, currently NI expects you to use a 96-pin to terminal breakout board or incorporate the 96-pin connector into your test fixture.
You can use a breakout board to form another custom cable combination.
https://www.winford.com/products/brkn4296.php
How many of the 96-pin do you need to route to your application?
Santhosh
Soliton Technologies
(348 Views)
Could you tell me if the DIN 96p has crimp or solder contacts?
(339 Views)
If you're asking the construction of the male-female cable, from the looks of it, it may be wires soldered to the connector through a PCB under the case.
I/O connector
Male ..........................................................96-pin Type R DIN 41612/IEC 60603-2
Female.......................................................96-pin Type C DIN 41612/IEC 60603-2
Santhosh
(324 Views)
