PXI
Internal connection MUX and DMM?
does anyone know if it's possible to get an internal connection (com-channel) between a MUX 2575 and a DMM?
I don't want to peel one wire off and loop it back to the pxi-system with the multimeter.
Thanks for reading
(3,872 Views)
Hi
MUX can be used to measure multiple voltages with a single DMM,  a MUX is designed to route a signal from multiple inputs to one single output, or vice versa.
For more information see How to Create Custom Switch Topologies with National Instruments Switch Executive
(3,844 Views)
