PXI
Is it possible to compile all the vi's into one?
Hello, is it possible to compile all the vi's and sub-vi's of my program into one, so that my application will be independent and will consist only of one vi. I don't have application builder.
Thank you in advance, Dima.
(3,015 Views)
Hi Dima,
Without Application Builder you cannot create an EXE or DLL from your code. It is also not really possible to create complex code in a single vi, LV is heirarchical by nature. You could use File>>Save with Options>>Development Distribution and this will save all of the vi hierarchy in a single labview library (.LLB) file which is then a lot easier to move around from machine to machine.
Hope this helps,
Nick
(3,011 Views)
