PXI
Is it possible to get High impedance with PXI 4130 in the OUTPUT DISABLE mode?
During the test execution in my project, I'm using PXI 4130 to force a voltage for a certain amount of time. At some Later Point, I'm using another source to force the same node, and I need PXI 4130, NOT to load [move to High Z / isolate] my other source.  The output Disable VI doesnt moves the output to a low resistance. Please Help.
Manu
(3,599 Views)
Hi Manu,
Unfortunately the 4130 does not have the ability to disconnect the output like the 4132 does. Here is some information about disabling the output from our DC Power Help:
17129i617E9943DBCE22A1
I would suggest that you could implement this type of behavior using a relay at the output of the 4130. This would give you the ability to disconnect the 4130 from your test pin.
Steve B
(3,547 Views)
