PXI
Is there any MXI-3 bulkhead connector available?
Need to find out P/N or manufacturer for MXI-3 bulkhead connectors (if there is any). Basically, I am builiding a system with a PXI chassis inside a rack, and need a solution to provide a connection to the chassis from the outside
(3,768 Views)
Which type of MXI-3 interface are you using?
For the PXI-PCI-8330 (Copper cable) the connector used is the BERG 73593. If you go to www.berg.com you can search for the connector and possibly mating components.
The copper cable used is the AMP 1-1324640-4. AMP has a really good website complete with product drawings. I'm sure it wouldn't be too hard to find individual components that would mate with the cable.
For the PXI-PCI-8335 (Fiber Optic cable) the connector used is actually built into the transceiver. Finisar's FTR-8509-2. I would recommend contacting them www.finisar.com for mate components.
Jonathan Hildyard
(3,768 Views)
