PXI
J1939 WITH VERISTAND ERROR
HAI
i am working with Pxi 8108 with veristand 2011, resently i download j1939 custom devices with NI XET 1.4
when i deploy the project in verisatnd i am faceing the following problem
• Starting VeriStand PC Engines...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target Controller.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -1074384758 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI-XNET:  (Hex 0xBFF6308A) The interface name given does not specify a valid and existing interface. Solution: Use a valid and existing interface. These can be obtained using MAX, XNET system properties, or the LabVIEW XNET Interface IO name. If you are using CompactRIO, refer to the topic "Getting Started with CompactRIO" in the NI-XNET Hardware and Software Help.
NI VeriStand:  NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi
• Shutting down VeriStand PC Engines...
• Unloading System Definition file...
• Connection with target Controller has been lost.
NOTE : when tryed to test the CAN interface (PXI-8512/2) using MAX>>Tools>>NI CAN>> RT hardware configuer test. The  port1(CAN0) get passed but  port2(CAN1) get failed screenhot i attached below
kindly help me in this problem
please help me the problem
Message 1 of 1
(4,449 Views)
