PXI
LVRT.DLL load address: 0x02110000
I have two PXI-8108 with the same aplication. Both PXI have the same problem. When I run the software or sometime after begun the PXI reboot due to system error. At one of them return a log message LVRT.DLL load address: 0x02110000.
I already reinstall the Labview RT 2011 at PC and PXI.
What else can I do?
(4,025 Views)
Hi Schimitz,
I note you are using LabVIEW 2011, have you ever install any LabVIEW install LabVIEW 2011 f2 patch?
http://joule.ni.com/nidu/cds/view/p/id/2657/lang/en
If you don´t do it yet i recommend do it and after reinstall RT software at PXI-8108.
Abel Souza
Applications Engineering
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,999 Views)
I already install this patch. I formatted the computer and reinstall the Labview, until now this error is not happening.
(3,997 Views)
