PXI
Libraries for NI PXI 5114
Sorry for such stupid questions, but I'm new to all this staff. I've installed *.ko module into Linux kernel.  Now I'm trying to locate library(s) for digitizer  to use them from C++ application.  I expected to find “*.a” files, but I didn’t find them. Instead of it I found libniScopeDMF2u.so.2.9.0
libnihsdcu.so.1.4.0
libnihsdlvexportu.so.1.1.0
libniScope_32.so.2.9.0
libnihsdeu.so.1.4.0
libnihsdru.so.1.4.0
in /NISCOPE-2.9.0f4/files/natinst/niscope/lib. Are these libraries what I need? Or this is LabView  staff?
Message 1 of 8
(5,603 Views)
I would start with the NI Modular Instruments Linux Installation Guide. The link is attached below:
http://zone.ni.com/devzone/conceptd.nsf/webmain/49A4EC056D73E34E8625714000701674
I hope this helps.
Evrem
NI Switzerland
Message 2 of 8
(5,586 Views)
🙂 I have read it. Not a word about C++ usage/libraries/e.t.c. I don't need to install LabView, I just need to use digitazer API functions from my C++ code.
Message 3 of 8
(5,583 Views)
What about the nilsdev-command, do this one returns the correct list of your installed boards?
If yes, then the next step would be to look at the examples, but there aren't any C++ example codes directly available.
Please read the Readme of the NI-Scope for Linux Installer for more informations:
Evrem
NI Switzerland
Message 4 of 8
(5,582 Views)
Thank you. I'll check.
Message 5 of 8
(5,573 Views)
I've made small own C++ project and try to compile it. I've included libniScope_32.so. At the link step it tells me :
/usr/bin/ld: warning: libivi.so.2, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnidmxfu.so.1, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnimhwcfu.so.1, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnimstsu.so.1, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnimdbgu.so.1, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libniorbu.so.1, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libnipalu.so.1, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: liblvrt.so.8.0, needed by /nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so, not found (try using -rpath or -rpath-link)
And then, I've got a set of "undefined reference" errors :
/nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so: undefined reference to `Ivi_UnlockSession'
/nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so: undefined reference to `_memDelete(void*)'
/nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so: undefined reference to `Ivi_LockSession'
/nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so: undefined reference to `libSetSSPackageClientLoadStatus(long)'
/nfs/cs-ccr-nfs1/vol30/src/dsc/drivers/niscope51/L86/NISCOPE-2.9.0f4/files/lib/libniScope_32.so: undefined reference to `_memNewUsingCRT(unsigned long, tMemAllocationFlags, long*)
If iI include libivi.so I get another set of undefined reference errors. Make files in the examples contain simple string like :"gcc -lniScope_32 Calibrate.c....."
It's not enought. Could anybody help me?
Message 6 of 8
(5,546 Views)
Ok. It looks like the onle solution is to incluse all of exist libraries.
Message 7 of 8
(5,520 Views)
so how does the problem solved?
I have miss the same question,I want to know how to resolve it .
here is the warning.
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libnivisidc.so.16, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libXext.so.6, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libX11.so.6, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libxcb.so.1, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libtbb.so.2, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libtbbmalloc.so.2, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libXft.so.2, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libavcodec.so.54, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libavformat.so.54, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libswscale.so.2, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libGCBase_gcc-4.7-oe_v3_0_NI.so, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libGenApi_gcc-4.7-oe_v3_0_NI.so, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so, not found (try using -rpath or -rpath-link)
f:/national instruments/eclipse/14.0/x64/sysroots/i686-nilrtsdk-mingw32/usr/bin/x86_64-nilrt-linux/../../libexec/x86_64-nilrt-linux/gcc/x86_64-nilrt-linux/4.7.2/ld.exe: warning: libnipalu.so.1, needed by F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so, not found (try using -rpath or -rpath-link)
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::RuntimeException::RuntimeException(char const*, char const*, int, char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `PropertyImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XSetScreenSaver'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::GenericException::GetDescription() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_open_input@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CNodeMapFactory::~CNodeMapFactory()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerUtility::convert(unsigned long, tTimerTimeUnit, tTimerTimeUnit, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_malloc'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `typeinfo for iThread'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::end()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::get_initial_auto_partitioner_divisor()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFreeColormap'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::const_iterator::operator++()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftDrawString8'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapterU3V::~CEventAdapterU3V()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `HowGenCodeImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::iterator::operator*() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::operator+=(char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::begin()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `sws_getCachedContext@LIBSWSCALE_2'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XCreateSimpleWindow'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_sub_q'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XSetForeground'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_alloc_frame@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `GetPartNameImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `pkgModulePackageEventLog'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tMemBlockReferenceBase::unassignExternalPointer(int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CastToIDestroy(GenApi_3_0_NI::INodeMap*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimedNotifier::isScheduled(int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_open2@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSyncAtomicU32::operator++(int) volatile'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_guess_format@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `tbb::task_scheduler_init::terminate()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::const_iterator::operator++()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSyncAtomicU32::~tSyncAtomicU32()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `typeinfo for tbb::task'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::allocate_continuation_proxy::allocate(unsigned long) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::gcstring(GenICam_3_0_NI::gcstring const&)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::~CChunkPort()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::begin()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XDrawLines'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::length() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::task_group_context::is_group_execution_cancelled() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XCreateGC'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::SetPortImpl(GenApi_3_0_NI::IPort*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFillRectangle'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::operator[](unsigned long)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_free'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFreeGC'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerTimebasePrecise::getCounterValue(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `LoadImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::const_iterator::operator!=(GenApi_3_0_NI::value_vector::const_iterator const&) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_decode_video2@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `MethodImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimedNotifier::tTimedNotifier(iTimedNotifierObserver*, unsigned int, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `CopyImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerTimeWasterSleep::sleep(unsigned long, tTimerTimeUnit, int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::GenericException::~GenericException()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_codec_get_id@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XCreateColormap'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_log_set_level'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapterGEV::~CEventAdapterGEV()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::concurrent_vector_base_v3::~concurrent_vector_base_v3()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::gcstring(char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerTimeWasterSleep::getResolutionTimeUnit(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_write_header@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `DoItImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::NFS_Allocate(unsigned long, unsigned long, void*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::end()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::allocate_child_proxy::allocate(unsigned long) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_free_packet@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::operator char const*() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerTimeWasterSleep::canSleepNow(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XDrawRectangle'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::value_vector()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tThreadUtility::sleep(unsigned int, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftFontOpen'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::concurrent_vector_base_v3::internal_capacity() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerTimebasePrecise::getResolutionValue(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avpicture_get_size@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `SetLabVIEWVersion'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::iterator::operator++()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::concurrent_vector_base_v3::internal_clear(void (*)(void*, unsigned long))'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XDrawArc'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::~gcstring()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `UnloadImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XDrawPoint'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSyncAtomicU32::operator=(unsigned int) volatile'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XAllocColor'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapter::AttachNodeMap(GenApi_3_0_NI::INodeMap*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XInitThreads'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XMoveWindow'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::Write(void const*, long, long)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimedNotifier::~tTimedNotifier()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_guess_codec@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `DisplayValImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::const_iterator::operator*() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftDrawCreate'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::CChunkPort(GenApi_3_0_NI::IPort*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::~node_vector()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `DrawImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `EditSelCoreImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `DPMSDisable'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::GenericException::what() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `sws_freeContext@LIBSWSCALE_2'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::const_iterator::operator*() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tMemBlockReferenceBase::getBlockSize(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `HeapCheckImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avio_close@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::size() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `vtable for tbb::task'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::const_iterator::operator!=(GenApi_3_0_NI::node_vector::const_iterator const&) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_close@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::AttachChunk(unsigned char*, long, long, bool)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XShmDetach'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_init_packet@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `ssprintf'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::GenericException::GetSourceFileName() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tMemBlockReferenceBase::assignExternalPointerNonShared(unsigned long, void*, int*, tMemAccessFlags, void*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::DetachChunk()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `_memNewUsingCRT(unsigned long, tMemAllocationFlags, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XShmCreatePixmap'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avio_open@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::gcstring()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tThreadUtility::getCurrentThreadId()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSyncAtomicU32::operator++() volatile'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XMapWindow'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_find_decoder@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::LogicalErrorException::LogicalErrorException(char const*, char const*, int, char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CNodeMapFactory::CNodeMapFactory()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::AccessException::AccessException(char const*, char const*, int, char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `typeinfo for GenApi_3_0_NI::CEventAdapterU3V'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::task::note_affinity(unsigned short)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CNodeMapFactory::GetSupportedSchemaVersions(GenICam_3_0_NI::gcstring_vector&) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CNodeMapFactory::CNodeMapFactory(GenApi_3_0_NI::EContentType_t, GenICam_3_0_NI::gcstring const&, GenApi_3_0_NI::ECacheUsage_t, bool)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XShmAttach'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::GenericException::GetSourceLine() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::GetPrincipalInterfaceType() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::operator=(GenICam_3_0_NI::gcstring const&)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tMemBlockReferenceBase::assignExternalPointerNonShared(unsigned long, void*, tMemAddressOrigin, int*, tMemAccessFlags, void*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_alloc_context@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `GenCodeImageControl2'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_encode_video@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_network_init@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `libSetSSPackageClientLoadStatus(int)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::NFS_Free(void*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::task_group_context::~task_group_context()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XShmCreateImage'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFreeColors'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_flush_buffers@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `sws_scale@LIBSWSCALE_2'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `syncClose(iSync*, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avcodec_find_encoder@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimerTimebasePrecise::getResolutionTimeUnit(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tThreadControllerFactory::destroy(iThreadController*, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::InvalidateNode()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::GetAccessMode() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_write_frame@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `HowDisplayImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XOpenDisplay'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::iterator::operator-(GenApi_3_0_NI::value_vector::iterator const&) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::OutOfRangeException::OutOfRangeException(char const*, char const*, int, char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `tbb::task_scheduler_init::initialize(int, unsigned long)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_close_input@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tThreadControllerFactory::create(tThreadControllerFactory::tParam const&, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::concurrent_vector_base_v3::internal_reserve(unsigned long, unsigned long, unsigned long)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `MouseImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_seek_frame@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftTextExtents8'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `typeinfo for GenApi_3_0_NI::CChunkPort'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSyncAtomicU32::tSyncAtomicU32(unsigned int)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avpicture_fill@LIBAVCODEC_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_write_trailer@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimedNotifier::setDuration(unsigned long, tTimerTimeUnit, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_freep'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::task_group_context::init()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_new_stream@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XShmPutImage'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `GenCodeImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSSVersion::toString(char*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFlush'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tMemBlockReferenceBase::getPointer(int*) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimedNotifier::cancel(int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFillArc'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `sws_getContext@LIBSWSCALE_2'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `DataPtrImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `typeinfo for GenApi_3_0_NI::CEventAdapterGEV'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XDrawLine'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::allocate_root_with_context_proxy::free(tbb::task&) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `typeinfo for GenICam_3_0_NI::GenericException'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XSetLineAttributes'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_register_all@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `avformat_find_stream_info@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tSyncAtomicU32::operator--(int) volatile'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFlushGC'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CChunkPort::Read(void*, long, long)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftDrawDestroy'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::const_iterator::operator<(GenApi_3_0_NI::value_vector::const_iterator const&) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `HowDrawImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_rescale_q'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::value_vector::~value_vector()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::node_vector()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tTimedNotifier::schedule(int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `av_read_frame@LIBAVFORMAT_54'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `_memDelete(void*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `tThreadUtility::yield(iThreadController*, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::GenericException::GenericException(char const*, char const*, unsigned int, char const*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::node_vector::const_iterator::operator+(long) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftColorAllocValue'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XSetClipRectangles'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFreePixmap'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `iThread::~iThread()'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::allocate_root_with_context_proxy::allocate(unsigned long) const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `syncOpen(iSync::tParam const&, int*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XFillPolygon'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapterGEV::DeliverMessage(unsigned char const*, unsigned int)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::c_str() const'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `tbb::internal::concurrent_vector_base_v3::internal_push_back(unsigned long, unsigned long&)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftDrawRect'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenICam_3_0_NI::gcstring::operator+=(GenICam_3_0_NI::gcstring const&)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapterU3V::DeliverMessage(unsigned char const*, unsigned int)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `SaveImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapterGEV::CEventAdapterGEV(GenApi_3_0_NI::INodeMap*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XftColorFree'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XCloseDisplay'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivissvc.so: undefined reference to `XSync'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `InitImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libnivision.so: undefined reference to `PopUpImageControl'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapterU3V::CEventAdapterU3V(GenApi_3_0_NI::INodeMap*)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CNodeMapFactory::CreateNodeMap(GenICam_3_0_NI::gcstring const&, bool)'
F:\JAVA\Eclipse_WORKSPACE\Helloxiafei\Debug\lib/libniimaqdx.so: undefined reference to `GenApi_3_0_NI::CEventAdapter::DetachNodeMap()'
collect2.exe: error: ld returned 1 exit status
15:39:29 Build Finished (took 327ms)
Message 8 of 8
(3,830 Views)
