PXI
Load cell simulation with PXI system
Just curious if any of you have tried to do this...
I'm using LabView and my PXI chassis to test a board that interfaces with a load cell. The load cell is 2mV/V with a 3volt excitation voltage so full scale would be 6mV. I was hoping to do a sweep in increments of 1mV. So two signals S1 and S2, e.g. S1=2.000 S2=2.001, S1=2.000 S2=2.002, then S2=2.003 etc...
The only analog outputs I have are the two 12 bit outputs form the 6040E MIO card...not enough resolution.
I was thinking maybe I could buy some sort of accurate multiplying DAC and control it with the Digital lines from my PXI system. Anyway I was just curious if any of you guys and gals had done something similar...or maybe there is a low cost pxi card that I could use...but
I doubt it...my budget is limited right now.
Thanks and regards
(3,311 Views)
Mashman,
Have you considered using an external reference to increase the resolution of the analog output channels on your 6040E? You could definitely get your code width below the 1 mV level that your application requires. Below are links to a couple of documents that discuss the use of external references:
Resolution of Analog Outputs
Outputting a Voltage Using an External Voltage Reference
Good luck with your application.
Spencer S.
(3,311 Views)
Ah, thanks Spencer. I can use an external 3.3V reference and get the resolution that I need.
Thanks!!
(3,311 Views)
