PXI
MAX does not detect my PXI-5122 and PXI-6551 cards in a PXI-1045 chassis.
I have been using a PC with MXI-3 to PXI-1045 chassis to develop LabView TestStand code.  Things are fine on my development PC.  [Software configuration report attached nireport_rich.txt].
I have a 2nd PC set aside to test my deployment packages.  I installed a GPIB card and MXI-3 card in my deployment test PC, and loaded a bunch of hardware drivers.  [Report attached nireport_depPC_0006.txt]
All the PXI cards are found just fine when my development PC is connected, but when I power up my deployment PC (with MXI-3 connected to the 1045 chassis) -- I can't import the development configuration [exported from development PC] because the deployment PC does not see the PXI-6551 DIO card in slot 6 [PXI6::10::INSTR] and the PXI-5122 card in slot 13 [PXI8::15::INSTR].
I keep reviewing the hardware driver versions installed, and the only small difference that I see at this point is that the deployment PC has a slightly older version of NI-Switch.
Anybody have any ideas of what I can try next?  I'm out of ideas.
. . . . hmmm, can't seem to attach more than one file, so here's the software info on the deployment PC
NI Software Information:
CVI Run-Time 7.0.0.395
NI-DAQ 7.3.0f1
NI-DAQmx 7.3.1f0
NI Script Editor 1.1
NI-DMM 2.3.1
     Soft Front Panel 2.3.0
NI-FGEN 2.2.1
     FGEN Soft Front Panel 2.2
NI-488.2 Software 2.30
IVI Compliance Package 2.2 2.2
LabVIEW Run-Time 7.0
Measurement & Automation Explorer 3.1.1.3003
Measurement Studio 6.0
     For Visual Basic
          ActiveX User Interface 7.0.0.344
          ActiveX 3D Graph 7.0.0.344
          ActiveX DataSocket 4.2.2.1
NI-USI 1.0.2
NI-HSDIO 1.2.1.3
NI-HWS 1.2.2.0
NI-PAL Software 1.8.2.0
NI-SCOPE 2.7.0f5
     SCOPE Soft Front Panel 2.1.0
NI Spy 2.2.0.12
NI-SWITCH 2.30.49153
NI-TClk 1.2
TestStand 3.1
NI-VISA 3.2
     visa32.dll 3.2.0.19
     NiVisaServer.exe 3.2.0.19
     NIvisaic.exe 3.2.0.19
LabVIEW Run-Time 7.1
Message 1 of 1
(3,314 Views)
