hello guys,
im using NI-pxie-5644R VST for channel emulation purpose.im running the channal emulation example https://decibel.ni.com/content/docs/DOC-26423.i have two VST.My application is to use 1 transmit and 1 receive antenna.However,when i input the signal to RF in of VST0,im able to observe the waveform.What about the RF Output??do i have to configure the other VST for RF Out for 1x1 antenna application or the same VST Is capable of generating the RF Output.I have tried getting the RF output from the same VST But there is no signal.Please help..
Thanks..
