I tried to set MXI-4cd it but I have a message that says components are already set (NI-VISA...).
But I have basically a problem with MAX Explorer which does not recognize the PXI system.
In my PC, the first PCI-slot is devoted to a NI PCI-6052E card.
The second one is devoted to the PCI8331 card.
I think the problem comes from the communication between the PCI-8331 in the PCI-slot and the PXI-8331 in the PXI-1031 chassis (bridge).
But this one doesn't seem to be recognized.
In MAX, there's just a device PCI-6052E in Traditional NI-DAQ-device or NI-DAQmx-device.
So if this card is not recognized, then the PXI system (that I powered on) cannot be recognized as well (PXI-1031 and its modules PXI-GPIB, PXI-7344, PXI-4204).
The communication must be wrong maybe because of the PCI-8331 which is not read from the PC? I wonder if the PCI-8331 in the 2nd slot at the moment should be set in the first slot instead of the PCI-6052E???
I tried the VISA option in MAX (show ALL PXI-PCI devices accessible to VISA instead of ONLY) and then to restart the system.
I tried as well to identify PXI as external PC or other (I can't load any PXI-1031 from CD: not a valid file), and to show PXI-buses: but PCI-6052E is shown?
Note: basically I think I can remove the PCI-6052E board (which we shouldn't use) since the Data acquisition can be down by the PXI-4204???
Thanks for quick answer.
Best regards
