PXI
MXI Express Fail with GigaByte MotherBoard
I'm using a PC with a GigaByte MotherBoard, Win7 32-bit
PCIe-8361 - PXIe-8360 - PXIe-1065 Chassis
My PC can only be booted by setting PCIe-8361 in Mode 1
In Mode 0, PC hang from the very begining, nothing show on the screen
MXI-Express BIOS Compatibility v1.3 installed but it doesn't work
MXIeBusDetect.exe run
Got 2 yellow icon from Device Manager for PCI Bridge with Error Code 12
No CardBus Driver installed
Latest PXI peripheral driver installed
Can anyone help? Thanks a lot!
John L.
(4,162 Views)
JHNLaw,
What's the Gigabyte model number?  And can you paste the output of MXIeBusDetect?
In device manager, please go to the properties of one of the bridges with the yellow icon.  On the details tab, select "Class upper filters".  What are the values?  If nothing is listed, go back to device manager and select view->Devices by connection.  Pick the bridge or root port just above one of yellow icons and get the class upper filters from it instead.
Thanks.
(4,154 Views)
I'm using gigabyte ga-880g-ud3h v1.x
http://www.gigabyte.com/products/product-page.aspx?pid=3448#ov
Result of MXIeResDetect.exe attached
Device Manager Result and Class Upper Filter attached
Thanks a lot for your help!
(4,145 Views)
The Last Post is actually posted by me, Thx
John L.
(4,141 Views)
Could you get the device manager screenshot again, but this time, viewing by connection?  (View->Devices By Connection).  I would like to see the relationship between the two bridges with the !'s.  Also, for each of those two bridges, could you go to the Details tab on the property sheet and get the Hardware IDs?
(4,126 Views)
