PXI
Mating connector for PXI-2568 cable?
I'm creating a test fixture and we are probably going to use the PXI-2568 (and mating cable ) to connect it, but want to plug the cable directly into my test fixture. I think there are a couple of D-62 standards, and I don't have the PXI-2568 yet to test.
Is this (for example) an appropriate connector to mate with the PIX-2568 cable?
http://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/5749639-1/A31926-ND/808312
(3,484 Views)
Accepted by topic author osbock
Hi Osbock,
The connector on the PXI-2569 is a standard 62-pin D-SUB, male connector so it appears that the connector you found should work for your test fixture.
I looked at the Accessories Section of the specification sheet and for a female front panel connector, all it says is 62-position D-SUB, female from any manufacturer, so I anticipate the same for the male connector on the other end of the cable.
http://www.ni.com/pdf/manuals/373787h.pdf
(3,450 Views)
