PXI
Max is not able to identify the cards
I have a PXI 1042 chasis with 8360 pxi card connected to a laptop running Vista.
5404, 6552, 2576, 6221, 4110 and 4130 are the cards installed in slots 2 to 7 respectively.
Under Devices and Interfaces > I can see the PXI-1042 "Chasis 1", but none of the cards have been identified.
Do I have to identify the cards manually? Or did I do something wrong while installing the software?
I am running Max 5.0.0, Labview 2011.
(4,232 Views)
Things tried so far :
Uninstalled everything and Installed everything back on the laptop.
Updated DAQMx - from ni.com to the latest version
Nothing helped.
Under System>Device Manager - I can see all the cards listed twice and with Device Status - "This device cannot find enough free resources that it can use. (code 12)"...
In MAX under Devices and Interfaces I can see PXI-1042 "Chasis 1" but model names are unknow/empty for all populated/unpopulated slots.
(4,220 Views)
Accepted by topic author vikasg
vikasg,
If you're seeing cards twice in device manager then there's something pretty wrong with the configuration.  I'd try the MXI-Express BIOS Compatibility software for something like this.  Make sure your NI ExpressCard-8360 is on the supported list, install the software, then run the utility it installs to change the mode of the ExpressCard (you only have to do it once).
http://joule.ni.com/nidu/cds/view/p/id/2071/lang/en
Until the cards show up properly in device manager they won't show up in MAX.
- Robert
(4,210 Views)
That helped, thank you Robert!
(4,206 Views)
