PXI
Max number of TCP connections simultaneously opened
I'm using a PXI-RT controller and i wish to know how manies TCP connection can be simultaneously opened on controller.
I've seen that if i try to open more than 8-10 connection i receive an error.
Does this value can be increased?
Ok... a real-time system shouldn't have so much connections...but i don't need determinism, just a remote control...
maybe if I install Windows on PXI, instead of pharlap?
(3,161 Views)
With the current IPv6 that's out, you should theoretically have 2^32 ports that are available on your TCP connection. Make sure you understand how to use MAX to configure the VISA server that pharlap sets up. Make sure that you have the IP addy correct when you set up the Remote DAQ configuration. Questions, write me @ spalog@sbcglobal.net
(3,161 Views)
