PXI
Maximum number of PXI-5154 modules that can be synchronized in a chassis?
If I want to synchronize multiple channels of the PXI-5154 module, what is the maximum number of modules I can synchronize using TCLK on the PXI backplane?  Is it possible to synchronize the modules across the different bus segments on a PXI 18-slot chassi?
Ron
(3,477 Views)
Hi Ron,
The maximum number of modules you can synchronize using TCLK in an 18 slot chassis is 17 modules.  TCLK will work across the different bus segments of the PXI.  You can even use TCLK to synchronize multiple chassis.  There may be some initial delay while waiting for your TCLK to sync all of these modules, but it will work.
Sarah Yost
Senior Product Marketing Manager
(3,464 Views)
