PXI
Maximum write to disc speed for NI Real-Time
I am trying to create a vi that will save data to the disc at about 60 MBps. To test for this I created a simple program to generate a random 2 MB string and then append that to a file 2000 times and time how long it takes to complete. For my desktop computer running Windows 7 and an NTFS drive I can get 80 MBps, but on a PXIe-8135 running Real Time (PharLap 13.1) I only get 20 MBps. What is my limiting factor on the write speed for the PXI computer? Is there a difference in write speed between FAT and Reliance? Will a faster hard drive result in faster write speeds?
(5,291 Views)
Hello Nissen6,
Could you share with us what are the specifications in the computer? When you ran the program in the PXI, did you had a chance to check the CPU usage level? Were there any other VIs running in parallel with this VI?
(5,229 Views)
