PXI
May I change pxi-8186's memory with DDR 333?
Dear All,
          I am using the pxi-8186's chassis. Its memory is 256M which is not enough. The test result is DDR, PC2100 (133 MHz), 256 MB.
            This kind of memory can't be bought. So may I use DDR333 to replace it?
         Thank you.
Hugo
(3,377 Views)
可以到NI购买内存条。
帖子被Roger.Fei在11-09-2007 02:11 PM时编辑过了
NISH AE Haiping.Fei
(3,364 Views)
