11-05-2008 03:22 AM
I´m working with a PXI 6232 and with this card I can supply the AI GND with 10 volts and I´m able to measure voltages within the range 0-20 volts, which is perfect for my needs.
I was wondering if I can do the same with the PXI 4351? I need to measure temperature with thermocouples in some transistors that have about 20 volts, and I dont think the card can handle this voltage.
11-11-2008 07:30 AM
Hello Hernar,
you should be able to use the PXI-4351 similar to the PXI 6232, since it is stated in the data sheet of the PXI 4351: "Each input should remain within ±15 V of ground".
I hope this information helps.
Blase
