PXI
Measurement & Automation Explorer
I have a PXI-8196 embedded controller that I would like to update its LabVIEW software to version 8.6.1. However, Measurement & Automation Explorer gives me the following error message:
The operation could not be completed. Operation failed with error code: 56.
Possible reason(s): Timed out while communicating with remote target.
What is the remedy here?
(3,648 Views)
Hey Cha,
Is your PXI-8196 embedded controller a Real-Time target or Windows controller?
If it is Windows based, you'll want to do one of these methods to install the upgraded version of LabVIEW to your controller:
1. Connect a USB-DVDROM drive to the controller and load your LabVIEW 8.6.1 disk
2. Download the installer from ni.com to the controller and install it
If it's a Real-Time target you may want to take a look at this KB. It explains your error and a solution.
David Pratt
Group Manager for Application Engineering Specialists | Automated Test
NIC
(3,639 Views)
